This command temporarily overrides one of the following parmlib attributes:
The override affects only the CA Vtape Subsystem that the command was issued for and remains in effect until it is overridden again, a REFRESH=OPTIONS console command is issued, or the Subsystem is stopped and restarted.
SVTn SET THRESHOLD FREEspace=nnn | HOLD=nnn | RELease=nnn | WARNing=xxx
Where:
Is a numeric value from 0 to 100
Is a value of -1 (minus 1) or a numeric value from 0 to 100.
You can determine the current setting of the attribute using the Display Parmlib command.
