This command controls the USS Backstore feature. It causes the CA Vtape to dismount all the UNIX mount points defined to USS Backstore.
This command is useful if you intend to stop an CA Vtape subsystem in order to change the RootDirectory= attribute in the Startup Options Section of parmlib.
To properly use this command, we recommend stopping all USS Backstore and Recall Activity while changing mount points.
Note: For a detailed description how to accomplish this task, see the section File System Reconfiguration in the Configuration Guide.
SVTn SET USS=UNMOUNT
Example of information displayed by the SET USS=UMOUNT command
SVT4 SET USS=UNMOUNT SVT4US304I 114,01AB,USS@FSUD,Unmount,Normal(10),VTAPEQA.TRIPLEX SVT4US304I 0,00,USS@FSUD,Unmount,Immediate(08),VTAPEQA.TRIPLEX SVT4X0100I Command Complete
In the example output, VTAPEQA.TRIPLEX is the name of the USS mount point defined to CA Vtape.
