Once you verify that there is indeed a problem and are able to isolate it to one of the supported categories (listed above), you may refer to the appropriate diagnostic procedure or checklist which is provided for each general category.
Each procedure is designed to either allow you to determine the cause and resolution of the problem yourself, or to assemble as much information as you can about the problem. This enables you to make effective use of any discussions you may have with CA Top Secret Technical Support.
Copyright © 2009 CA.
