Previous Topic: CICS Specific SuboptionsNext Topic: User Facilities
General Information
ACEP
INITPGM=ACE    ID=A  TYPE=27
ATTRIBUTES=ACTIVE,SHRPRF,ASUBM,NOABEND,MULTIUSER,NOXDEF
ATTRIBUTES=LUMSG,STMSG,SIGN(M),INSTDATA,NORNDPW,AUTHINIT
ATTRIBUTES=NOPROMPT,NOAUDIT,RES,WARNPW,NOTSOC,LCFCMD
ATTRIBUTES=MSGLC,NOTRACE,NODORMPW,NONPWR
MODE=FAIL  LOGGING=INIT,MSG,SEC9
UIDACID=8  LOCKTIME=000   DEFACID=*NONE*  KEY=8
APPC
INITPGM=ATB    ID=AP TYPE=03
ATTRIBUTES=IN‑USE,ACTIVE,NOSHRPRF,NOASUBM,NOABEND,MULTIUSER,NOXDEF
ATTRIBUTES=MSGLC,NOTRACE,EODINIT,DORMPW,NONPWR
MODE=WARN  DOWN=GLOBAL  LOGGING=INIT,MSG,SEC9
MAXUSER=03000  PRFT=003
BATCH
INITPGM=IEFIIC    ID=B   TYPE=01
ATTRIBUTES=IN‑USE,ACTIVE,SHRPRF,NOASUBM,ABEND,SUAS,NOXDEF
ATTRIBUTES=NOPROMPT,NOAUDIT,RES,NOWARNPW,NOTSOC,LCFCMD
MODE=FAIL  LOGGING=INIT,MSG,SEC9,SMF
CA7
INITPGM=UCC   ID=U  TYPE=025
ATTRIBUTES=NOLUMSG,NOSTMSG,SIGN(M),INSTDATA,NORNDPW,AUTHINIT
ATTRIBUTES=MSGLC,NOTRACE,NOEODINIT,IJU,NODORMPW,NONPWR
MODE=WARN DOWN‑GLOBAL LOGGING=ACCESS,INIT,SMF,MSG,SEC9
CICSPROD
INITPGM=DFH          ID=C  TYPE=004
ATTRIBUTES=IN‑USE,ACTIVE,SHRPRF,ASUBM,NOABEND,MULTIUSER,NOXDEF
ATTRIBUTES=LUMSG,STMSG,SIGN(M),INSTDATA,RNDPW,AUTHINIT,
ATTRIBUTES=NOPROMPT,NOAUDIT,RES,WARNPW,NOTSOC,LCFTRANS
ATTRIBUTES=LUUPD
MODE=FAIL  DOWN=GLOBAL  LOGGING=INIT,SMF,MSG,SEC9
FACMATRX=YES  EXTSEC=YES  EJBRPRFX=NO
XJCT=NO XFCT=YES XCMD=NO XDCT=NO XTRAN=YES XDB2=NO XEJB=NO
XTST=NO  XPSB=NO   XPCT=NO  XPPT=NO   XAPPC=NO   XUSER=NO
PCTEXTSEC=HONOR    PCTCMDSEC=HONOR    PCTRESSEC=OVERRIDE
DSNCHECK=YES  LTLOGOFF=NO   RLP=NO   SLP=NO   PCLOCK=NO
MAXUSER=03000   PRFT=003  MAXSIGN=010,RETRY
CICSCACHE=TASKLIFE,NOAUDIT,0512
FACILITY DISPLAY FOR CICSPROD
BYPASS TABLE DISPLAY FOR FACILITY CICSPROD
RESOURCE=LOCKTIME BYPASS NAMES: TSS
RESOURCE=TRANID BYPASS NAMES: CAQP CATA CATD CATP
   CATR CAUT CCIN CCMF CDBD CDBN CDBO CDBT
    CDTS CECS CEGN CEHP CEHS CESC CESF CESN
    CFTS CGRP CITS CLQ2 CLR1 CLR2 CLS3 CLS4
    CMPX CMTS CNPX COVR CPLT CPMI CQPI CQPO
    CQRY CRDR CRMD CRSQ CRSR CRSY CRTE CRTR
    CSAC CSCY CSFU CSGM CSGX CSHR CSIR CSJC
    CSKP CSLG CSMI CSM1 CSM2 CSM3 CSM4 CSM5
    CSNC CSNE CSPG CSPK CSRK CSPP CSPQ CSPS
    CSRS CSSC CSSF CSSN CSSX CSSY CSTA CSTB
    CSTE CSTP CSTT CSXM CSXX CSZI CVMI CVST
    CWTR CXCU CXRE CXRT TS   8888 9999 ....
    .... .... .... .... .... CFTL CFSL CKTI
    CKAM CFCL CIOD CIOF CIOR CIRR CJTR CSHA
    CSHQ CSOL CTSD CWBG CWXN CDBF CEX2 CFQR
    CFQS CSFR CSQC CDBQ CRMF CLSG CFOR CJMJ
    CLS1 CLS2 CPIH CPIL CPIQ CRTP CWXU CFTS
    CPIR
RESOURCE=TRANID PROTECT NAMES: CEDF TSS TSSC
CICSTEST
INITPGM=DFH          ID=k  TYPE=004
ATTRIBUTES=LUUPD
FACILITY DISPLAY FOR CICSTEST
BYPASS TABLE DISPLAY FOR FACILITY  CICSTEST
    CPIR
COMPLETE
INITPGM=THR    ID=C   TYPE=21
CONSOLE
INITPGM=***    ID=CN  TYPE=02
ATTRIBUTES=ACTIVE,NOSHRPRF,NOASUBM,MULTIUSER,NOXDEF
ATTRIBUTES=MSGLC,NOTRACE,EODINIT,DORMPW,NONPWR,
MODE=FAIL  DOWN=BYPASS  LOGGING=ACCESS,INIT,SMF,MSG,SEC9
DB2PROD
INITPGM=CAD    ID=DB  TYPE=100
ATTRIBUTES=NOPROMPT,NOAUDIT,NORES,WARNPW,NOTSOC,LCFTRANS
DB2TEST
INITPGM=CAD   ID=DT   TYPE=100
ENVIRON
INITPGM=ENV    ID=E   TYPE=15
ATTRIBUTES=ACTIVE,SHRPRF,NOASUBM,ABEND,MULTIUSER,NOXDEF
ATTRIBUTES=NOPROMPT,NOAUDIT,NORES,WARNPW,NOTSOC,LCFCMD
MODE=FAIL
HSM
INITPGM=ARC    ID=H  TYPE=099
ATTRIBUTES=IN‑USE,ACTIVE,SHRPRF,NOABEND,SUAS,NOXDEF
ATTRIBUTES=NOASUBM,MSGLC,NOEODINIT,IJU
ATTRIBUTES=NOTRACE,NODORMPW,NONPWR
MODE=WARN  DOWN=GLOBAL LOGGING=INIT,SMF,MSG,ACCESS,SEC9
IDMSPROD
INITPGM=RHD    ID=M  TYPE=11
MODE=FAIL  LOGGING=ACCESS,INIT,MSG,SEC9
IDMSTEST
INITPGM=RHD    ID=Q  TYPE=11
IMSPROD
INITPGM=DFS    ID=I  TYPE=05
IMSTEST
INITPGM=DFS    ID=X  TYPE=05
INTERACT
INITPGM=MEN    ID=I  TYPE=14
UIDACID=8  LOCKTIME=000   DEFACID=*NONE*  KEY=5
JES
INITPGM=HAS    ID=J  TYPE=12
ATTRIBUTES=ACTIVE,NOSHRPRF,NOASUBM,NOABEND,MULTIUSER,NOXDEF
ATTRIBUTES=MSGLC,NOTRACE,DORMPW,NONPWR
OPENMVS
INITPGM=IEFIIC   ID=OE TYPE=093
ATTRIBUTES=IN‑USE,ACTIVE,NOSHRPRF,NOASUBM,NOABEND,SUAS,NOXDEF
ATTRIBUTES=MSGLC,NOTRACE,EODINIT,IJU,DORMPW,NONPWR
MODE=WARN  DOWN=GLOBAL  LOGGING=INIT,SMF,MSG,SEC9
NCCF
INITPGM=DSI    ID=N  TYPE=06
ATTRIBUTES=ACTIVE,SHRPRF,ASUBM,ABEND,MULTIUSER,NOXDEF
ATTRIBUTES=LUMSG,STMSG,SIGN(M),INSTDATA,NORNDPW,NOAUTHINIT
ATTRIBUTES=MSGLC,NOTRACE,NODORMPW,NONPWR,NOEODINIT,IJU
MAXUSER=03000, PRFT=003 LOGGING=INIT,MSG DOWN=GLOBAL
ROSCOE
INITPGM=ROS    ID=R  TYPE=07
ATTRIBUTES=NOTRACE,NODORMPW,NONPWR,MSGLC
STC
INITPGM=IEESB605    ID=S  TYPE=02
ATTRIBUTES=LUMSG,NOSTMSG,SIGN(M),INSTDATA,NORNDPW,AUTHINIT
TONE
INITPGM=TON    ID=T  TYPE=13
ATTRIBUTES=NOPROMPT,NOAUDIT,RES,WARNPW,TSOC,LCFCMD
TSO
INITPGM=IKJEFLC    ID=T  TYPE=03
UNICNTR
INITPGM=***    ID=UN  TYPE=104
ATTRIBUTES=IN‑USE,NOSHRPRF,NOASUBM,NOABEND,MULTIUSER,NOXDEF
ATTRIBUTES=MSGLC,NOTRACE,NOEODINIT,IJU,DORMPW,NONPWR
MODE=WARN  DOWN=GLOBAL  LOGGING=MSG,SEC9
VAMSPF
INITPGM=VAM    ID=V  TYPE=09
ATTRIBUTES=ACTIVE,SHRPRF,NOASUBM,NOABEND,MULTIUSER,NOXDEF
VM
INITPGM=TSS    ID=V  TYPE=08
ATTRIBUTES=IN-USE,LUMSG,STMSG
ATTRIBUTES=ACTIVE,SHRPRF,NOASUBM,ABEND,SUAS,NOXDEF
ATTRIBUTES=NOLUMSG,NOSTMSG,SIGN(M),INSTDATA,RNDPW,AUTHINIT
WYLBUR
INITPGM=UEX    ID=W  TYPE=10
ATTRIBUTES=MSGLC,NOTRACE,NODORMPW,NONPWR,NOSIOCHK
UIDACID=8  LOCKTIME=000  LTLOGOFF=NO DEFACID=*NONE*  KEY=8
