A metadata model consists of objects belonging to the object types such as: entities, relationships, and associations; and each object is identified by a unique entity ID. You can use repository dialog to view the entities along with their associations and relationships, and understand how they relate with each other.
CA Repository Webstation Option objects belongs to specific metadata models and objects belonging to specific models are grouped into views, known as Repository Dialog. All objects belonging to a dialog support a particular functional area. For example, the DB2 dialog will display all objects that define DB2 definitions along with their associations and relationships. Repository dialog displays objects as a tabular list.
You can access repository dialog on the main menu to navigate to the object you want to update. You can access only one dialog at a time.
This section contains the following topics: |
| Copyright © 2009 CA. All rights reserved. | Email CA about this topic |
