About Attribute Detail Page
The attribute detail page displays attributes and its values in editable text boxes. The page also displays Search, Insert, Update, Delete, and Clear All buttons. You can enter data into the text boxes and choose to search, update, or insert an attribute. You can also perform impact analysis and text processing on selected rows.
All data modification actions are performed from the detail page only. However, the data being changes may or may not require prior approval by steward. A steward is a workstation associated with a privilege assigned to a list of users having approval rights. There are two possibilities regarding data modifications:
The attribute detail page stores the data entered through the text boxes in the form of XML stream. In addition to the actual data, the XML stream also contains the steward name (If a steward is associated with the data being changed). If the data is already associated with a steward, that steward name is highlighted. There can be be more than one stewards assigned for one repository object.
The approval requirement procedure checks whether approval is required for the current action.
The procedure call results in one of the following three actions depending on the input data:
The attribute detail page has a Breadcrumb feature for easy navigation. It appears on the upper left corner of the details page, allowing you to see your current location as well as previous locations as a path. You can use this feature to go back to any previous location. The browser back button is disabled for navigation.
From the attribute detail page you can perform the following actions:
Display a List of Stewards
The following query fetches a list of stewards:
SELECT *
FROM DBX_WORKSTATION_D W, DBX_XREF X
WHERE X.ENT_TYPE = 25123 AND X.ENT_ID = W.ENT_ID
Display a List of Stewards for a Particular Row
The following query fetches a list of stewards for a particular repository row:
SELECT NAME
FROM DBX_WORKSTATION_D D, DBX_WKSN_XREF WX
WHERE WX.ENT_ID = :Input entity id AND WX.WKSN_ID = D.ENT_ID;
RZOS--Display a List of Objects for a Specified Repository Dialog
CA Repository Webstation Option executes the following query to get a list of objects for a specified dialog:
SELECT DISTINCT X.ENT_NAME, X.ENT_TYPE,
CASE
  WHEN  X.TYPE2 = 'SET' THEN X.TYPE2
  ELSE  X.TYPE1
  END AS TYPE
FROM
TABLE( SELECT DISTINCT Z.ENT_NAME, Z.ENT_TYPE, Z.TYPE1, Y.TYPE2
       FROM
       TABLE(
       SELECT DISTINCT E.ENT_NAME, E.ENT_TYPE,
            CASE
            WHEN E.ASSOCIATION = 'Y' THEN 'ASSOCIATION'
            WHEN E.ASSOCIATION = 'N'
               AND E.SOURCE_ENT_TYPE <> 0
               AND E.TARGET_ENT_TYPE <> 0
           THEN 'RELATIONSHIP'
           ELSE 'ENTITY'
           END AS TYPE1
       FROM DBX_DIALOG D, DBX_ENT_TYPE_DESC E
       WHERE D.ENT_TYPE = E.ENT_TYPE
           AND D.DIALOG = :Input dialog name
       ) AS Z
     LEFT OUTER JOIN
       TABLE(
       SELECT DISTINCT E.ENT_NAME, E.ENT_TYPE, 'SET' AS TYPE2
       FROM DBX_DIALOG D, DBX_ENT_TYPE_DESC E,
             DBX_SET_TYPE S
            AND E.ENT_TYPE = S.SET_ENT_TYPE
            ) AS Y
     ON Z.ENT_TYPE = Y.ENT_TYPE
 ) AS X
When this query executes, the output is displayed as follows:
ENT_NAME  ENT_TYPE  TYPE
PROGRAM        151  ENTITY
RECORD         200  ENTITY
GROUP          201  ENTITY
ALIAS          202  ENTITY
EL VALUE       203  RELATIONSHIP
ELEMENT        204  ENTITY
ELEMENTS       205  SET
FIELD          207  RELATIONSHIP
FIELDS         208  SET
VALUE          209  ENTITY
FUNCTION       210  RELATIONSHIP
LOGIC AL       212  ASSOCIATION
PHY AL         213  ASSOCIATION
RECSEGS        214  SET
RZOS--Display a list of Dialogs Accessible for a User
The following query displays a list of dialogs that a particular user is authorized to use:
SELECT DISTINCT (D.DIALOG)
FROM DBX_PRIV_USER U, DBX_DIALOG_PRIV D
WHERE TSO_LOGON = :input name AND
      D.PRIV_NAME = U.PRIV_NAME
Copyright © 2009 CA. All rights reserved. Email CA about this topic
