Previous Topic: Configuring Archiving for Interaction Request FormsNext Topic: Accept or Override Policy at Environment Level
Define Domain Level Setting for Archiving
You can define the default interval to retain interaction request form instances at the Domain level.
  1. Click the Configuration tab.
  2. On the Configuration Browser pane, right-click Domain and select Lock.
  3. Click the Modules tab, right-click a process control module, and select Edit.
  4. On the process control module Properties tab, type a value in the Time to Keep Completed User Interaction field. The default value is 2 minutes.
  5. Click Apply.
  6. Click Save.
  7. Right-click Domain and select Unlock.
