Previous Topic: Submit a Start Request from CA Process AutomationNext Topic: Manage Archive Library Instances
Viewing Schedules
The Schedules palette in the Operations tab displays the running instances of the tasks that are scheduled. The schedule displays the following information columns for each task:
Task
The name of the task.
Start Time
The start time for a task.
End Time
The time the task ends.
State
The current state of the task.
Type
The type of operation that the task schedules.
Calendar
The Calendar parameter that is specified for the task.
Exclude
The vacation calendar that is specified for the task.
Scheduled Time
The time at which the task was scheduled to start.
Schedule
Specifies the path of the schedule object.
Content Package Name
The name of the content package to which the object belongs (if the object was imported in a content package).
Content Package Release Version
The release version of the content package (not of the specific object), if the object was imported in a content package.
This section contains the following topics:
Manage Schedules
Manage Schedules
The following procedure describes how you can manage the schedules from the Operations tab.
  1. Log in to CA Process Automation.
  2. In the Operations tab, click Schedules.
  3. Expand the folders and select the target task.
    The Schedules pane lists the tasks that are scheduled.
  4. You can filter to view the tasks that are based on the start date or the other available fields.
  5. Right click a task, the following option appears:
    Reset
    Resets the start time and the task state changes to the default On hold state.
    Release Hold
    Release the task that is in On hold state and the task state changes to Idle.
    On Hold
    Keeps a task in On Hold state.
    Dataset
    View system and process information for the task.
    Task Properties
    Lets you change the time, program, and execution settings.
    Time — Provide the start time, end time, frequency to repeat the task at regular intervals.
    Program — Specify the program name that you want to execute on the host computer.
    Execution Settings — Provide the target and the timeout details.
  6. (optional) Select the Archived option button to view the archived tasks.
