Previous Topic: About the Start Request FormNext Topic: Viewing Schedules
Submit a Start Request from CA Process Automation
If you have the required permissions, you can submit a start request from the Start Request pane in the Operations tab. In CA EEM, you are granted Start permission on the start request form object through a custom policy on the start request form.
If you check out and modify one or more automation objects used in the process invoked with the start request form, your private checked-out copy is loaded and executed. That is, you can execute and test your own checked out version of objects in a process without first checking them in or making them current.
  1. Log in to the CA Process Automation web interface.
  2. Open the Start Request pane in the Operations tab.
  3. Navigate to the target start request form, right-click the form, and select Start.
  4. Set the parameters on the first page and click Finish, if this button is displayed. Otherwise, click Next.
  5. If the page does not include the Queue request immediately setting, set the parameters, and click Finish, if the button is displayed. Otherwise, click Next.
  6. If the page displays the Queue request immediately setting, take one of the following actions:
  7. (Optional) When processing begins, monitor the Process instance in Process Watch.
