Previous Topic: Open an Instance of a ProcessNext Topic: Monitor Operators
Access the Process State
When the process designer displays a running or completed instance of a process, the display is periodically updated to show the current state of the process. The operator color coding scheme indicates the state of operators in an instance. A small indicator also appears on the top left corner of an icon when its operator is running, completed, or failed.
You can suspend a running process instance for editing. Once a process has completed or aborted, you can no longer change the process instance.
