View Orchestrator process instances on the Process Instances pane. You can use either the Process Instances pane or a Process Watch object to monitor and edit an instance. The Process Instances pane filters instances on an Orchestrator by state.
The Process Instances pane displays the instances. The State filter is enabled by default and displays instances in the following states:
The product displays the selected date range for the instance filter.
Displays the instances that result from the specified process filter.
Displays the state of each instance.
Displays the progress of each process.
Indicates the status of each runtime process instance for which you defined the duration.
Displays the start time of each process.
Displays the end time of each process, if applicable.
Identifies the user who started each process.
Displays the touchpoint on which each process instance in the selected state resides.
Displays the name of the content package to which the process belongs (if you imported the process in a content package).
Displays the release version of the content package (not the specific process) if you imported the object in a content package.
Opens the Process Designer in debug mode so you can monitor and control how the instance runs. To open the instance, double-click it.
You can change a suspended process instance. Your changes affect only the current instance. To save the changes, export the instance and then import it to a Library.
Stops the selected process instance. You can stop a process instance when it is blocked, breakpoint suspended, running, suspended, or waiting.
Suspends the selected process instance. You can resume a suspended process instance.
Resumes the selected process instance. You can resume a suspended or breakpoint suspended process instance.
Exports the selected process instance to an object export file. To save changes to a process instance, use the Export command. Later, you can use the import option in the context menu of a folder in the Library Browser to create a process object. You can export a process instance when it is blocked, suspended, running, or waiting.
Displays more information about the selected process instance.
You can also use the toolbar to access all of the options that are available for a process.
Copyright © 2014 CA.
