Previous Topic: Access the Process StateNext Topic: Manage Tasks
Monitor Operators
The operator shows a module that is currently executing operators.
  1. Launch the CA Process Automation web interface, then click the Operations tab.
  2. Under Links, click Operators.
  3. Examine the displayed data, using the following field definitions.
    Instance
    Lists all active operators. To limit the display, set the date filter or instance filter or state filter.
    State
    Specifies the state of the operators.
    Type
    Specifies the underlying module to which the operator belongs.
    Start Time
    The start time of the operator.
    Caller
    Specifies the actual process or agenda to which the operator is associated.
    Caller Node
    Applies to Active operators.
    Caller Type
    User
    Identifies the user who started the operator.
    Note: Expand the drop-down arrow next to each field to sort, view specific columns, and apply different filters.
  4. To display properties, right-click an operator instance and Properties.
  5. To open the process instance that invoked the operator, right-click a selected operator and select Open.
  6. Select the drop-down arrow for all the field definitions to set the Filter option.
  7. To display all the operator instances with a specific state, select the right drop-down filter next to State. By default only Running operator instances are displayed. In addition to the default states, you can select one or more of the following filters to view operator instances with other states.
  8. To update the displayed data, click the Refresh button in the toolbar.
