Previous Topic: Managing Archived Library ObjectsNext Topic: Configuring Archiving for Interaction Request Forms
Override the Orchestrator Archive Policy at the Object Level
A content designer defines the object-based policy for specific objects to override the default archival policy that is inherited from an Orchestrator. Define the object-specific policy to specify the minimum days of process history to archive and the minimum number of failed and completed instances.
  1. Click the Library tab.
  2. In the Library Browser pane, open the target folder and right-click an object of one of the following types:
  3. Select Properties.
  4. On the Properties pane, click the Archival Policy tab.
  5. Clear the Inherit Archival Policy from Orchestrator check box. Clearing the check box lets you edit associated fields.
  6. Specify values for the following fields:
  7. Click Save.
    The archive policy is defined for the selected object.
