If you install CA Process Automation on dual stack (IPv4 and IPv6) network environments, CA Process Automation may fail to boot up.
Symptom:
When you install CA Process Automation on dual stack (IPv6 and IPv4) network environments, you may experience issues while bringing up or accessing the following CA Process Automation components across network:
Solution:
Disable IPv6 stack on the host system where any of the following CA Process Automation components are running and restart the services:
Copyright © 2014 CA.
