Previous Topic: Object Properties: Form Tab (Interaction Request Form)Next Topic: Object Properties: General Tab
Object Properties: Form Tab (Start Request Form)
The Form tab for a start request form contains the following fields:
Left pane
Form Elements folder
Contains all of the available types of elements to include on a form.
All of the form elements are explained in the Content Designer Guide.
Start Request form folder
Contains the Page Layout folder, which includes the Page element for your form. The Page element is the canvas that you can build your form on. You can drag and drop form elements to the pages of your form here.
Middle pane
Form Pages
The layout for the pages of your form appears here. Click a control to edit its properties. For forms with multiple pages, click Back and Next to view other pages. Users can also click Next and Back to view the form pages.
You can drag and drop form elements from the left pane to the page to design the forms.
Right pane
Property Pane
Use this pane to view or edit the variables in the form elements. For example, set the Invisible property to true, change the Label that identifies a field, or specify a function for an event.
