The General properties of every library object contain the following fields:
Note: All properties are read-only except Description.
Specifies the object name.
Specifies the version of the object.
Specifies the object type for this automation object.
Specifies the user ID of the user who created this object.
Specifies the user ID of the user who modified this object last.
Specifies when the object was created.
Specifies when the object was modified.
Specifies the folder path for the object.
Specifies the name of the Orchestrator on which this object runs.
Specifies the object description.
This check box specifies whether an operator accessing a named dataset from the Library takes a global, cluster-wide lock.
Values: This check box has one of the following values:
Default: Cleared for new dataset objects. Imported dataset objects from previous versions have their check box selected by default.
Copyright © 2014 CA.
