The Form tab for an interaction request form contains the following fields:
Contains all of the available types of elements to include on a form.
All of the form elements are explained in the Content Designer Guide.
Contains the Page Layout folder, which includes the Page element for your form. The Page element is the canvas that you can build your form on. You can drag and drop form elements to the pages of your form here.
The layout for the pages of your form appears here. Click a control to edit its properties. For forms with multiple pages, click Back and Next to view other pages. Users can also click Next and Back to view the form pages.
You can drag and drop form elements from the left pane to the page to design the forms.
Use this pane to view or edit the variables in the form elements. For example, set the Invisible property to true, change the Label that identifies a field, or specify a function for an event.
Copyright © 2014 CA.
