The Form tab for a custom operator contains the following fields:
Contains all of the available types of elements to include on a form.
All of the form elements are explained in the Content Designer Guide.
Displays the structure of your form. Drag and drop form elements to the pages of your form from here.
A custom operator may require additional parameters as input into the function of the operator. You can add property pages to group these additional parameters. When you add pages to the custom operator to this section, they appear as expandable sections in the Properties palette of the Process Designer.
After creating property pages, you can add customizable parameters (fields) to them, nested beneath the page layout level.
Each custom operator can have one or more pages of parameters that are based on its ancestor or base operator. You can modify and configure these parameters. All operator parameters are described in the Content Designer Reference.
Use this pane to view or edit the variables in the form elements. For example, set the Invisible property to true, change the Label that identifies a field, or specify a function for an event.
Copyright © 2014 CA.
