Previous Topic: Object Properties: Custom Icon TabNext Topic: Object Properties: Form Tab (Custom Operator)
Object Properties: Duration Tab (Process)
The Duration tab contains the following fields:
Enabled
Specifies whether you can define the run interval for a process.
Values: This check box has one of the following values:
Default: Cleared
Expected Duration
Defines the expected duration for a process (in days, hours, and minutes).
Warning Threshold
Defines how far in advance the user is warned when the process run exceeds its expected duration.
