Previous Topic: itpam--Object Properties: Basic Tab (Calendar) (v4.2)Next Topic: Object Properties: Duration Tab (Process)
Object Properties: Custom Icon Tab
The Custom Icon tab is specific to the Custom Icon automation object. The tab lets you select a base icon graphical element from a list and add an icon modifier to the base icon. As you make a selection, the result is displayed in the Custom Icon Preview area.
Object Properties: Dataset Tab (Custom Operator)
The Dataset tab lets content designers define and group operator dataset variables that contain information that a custom operator returns. The configurations and settings in the Dataset palette of a custom operator are the same as for any other dataset. For each output parameter name/value pair on the left, you can configure whether to hide the parameter value from output.
Hide from output
Specifies whether to include the parameter with the output.
