The Runtime Security controls ensure that users without proper permissions cannot start a process.
Specifies whether to enable or disable the runtime security explicitly or through an inheritance option.
Note: When you explicitly enable or disable the run-time security, changes to inherited settings have no impact.
Default: Inherit from Orchestrator
Specifies whether to run processes with the permissions of either the process owner or the user who started the process instance. This check box is active only when you set the Runtime Security property to Enabled or Inherit from Orchestrator. Only Environment Content Administrators or the process owner can select this check box.
Default: Cleared
Specifies whether to automate the operator recovery. This option applies to process objects only. Recovery applies to specific operators that fail with a SYSTEM_ERROR. Operators subject to recovery must be part of processes that are in a Blocked, Running, or Waiting state.
Default: Selected
Copyright © 2014 CA.
