Previous Topic: Object Properties: Runtime Security Tab (Process objects)Next Topic: Object Properties: Settings Tab (Custom Operator)
Object Properties: Runtime Security Tab (Schedule)
The Runtime Security controls ensure that users without proper permissions cannot start a process. The runtime security can be enabled or disabled either explicitly or through an inheritance option. When set explicitly, changes to inherited settings have no impact. The Runtime Security tab contains the following fields:
Inherit from Orchestrator
This default value sets security settings as inherited from the Orchestrator.
Enable
Enabling runtime security allows CA Process Automation to verify permissions of a user before accessing automation objects from the database. Once enabled, runtime security enforcement is used when a process starts.
Disable
Disabling runtime security ensures backward compatibility for existing processes during, for example, system upgrades. Processes continue to run as they have before this release.
