Previous Topic: Object Properties: Runtime Security Tab (Schedule)Next Topic: Object Properties: Tags Tab
Object Properties: Settings Tab (Custom Operator)
Target
Specifies where the custom operator is to run.
Target is a calculated expression.
Specifies that the Target entry is a calculated expression. Calculated expressions specify a target dynamically at runtime. Consider the following examples:
Important! When a process is destined for an import as a content package, specify the IP address or FQDN in a dataset. A dataset can be modified in the import environment, but the Target field cannot.
Match target in Host Groups only?
Specifies the search scope for an operator target when the Target field entry is an IP address or a host name (FQDN). The operator execution on the target can proceed only when the target is known to CA Process Automation. Select Disabled to allow the broadest search. Select Enabled here and Disabled for the next field for the most restricted search.
Note: A DNS lookup of a specified hostname finds associated IP addresses; a DNS lookup of the IP address finds associated hostnames.
Values: The drop-down list has the following values:
Default: Inherit
Lookup DNS when matching target in Host Groups?
When the "Match target in Host Groups only" is set to Enabled, specifies whether to limit the search through Host Group references to the entry type. For example: When the Target field entry type is an FQDN, search only host name patterns. When the Target field entry type is an IP address, search only subnets. When a DNS lookup is included, the search can also accept a host group reference to the other type, as resolved by a DNS lookup.
Values: This drop-down list has the following values:
Default: Inherit from Environment.
Target is Read-Only
Indicates the target is read-only and cannot be changed.
Run as Caller User
Indicates the operator runs as if it were the calling entity.
'Run as Caller User' is Read-Only
Indicates the operator runs as if it were the calling entity, but as read-only so that it cannot be changed.
Group
Specifies a group name for your custom operator. This setting is used as the title of the group or folder in the Operators palette. You can use the same group name for related custom operators so that they all appear under the same folder in the Operators palette. The Custom Operator Group configuration defines common parameters and values for custom operators in the group.
Display Name
Indicates the name that is shown in the Operators palette with the icon for your custom operator. The name should be short and based on the function of your operator. Display Name is also used to provide the initial value for the Name field on the Information page of the Operator Properties. You can use any combination of letters, digits, spaces, and underscore characters.
Custom Operator Pre-execution
Specifies any code that must be performed before the custom operator runs.
Custom Operator Post-execution
Specifies any code that must be performed after the custom operator runs.
