Previous Topic: Upgrade a Nonclustered OrchestratorNext Topic: Carry Out Post-Upgrade Tasks
Upgrade a Cluster Node
When you upgrade a clustered Orchestrator, you upgrade one node at a time, beginning with any node in the cluster.
  1. Log onto the host on which a cluster node is installed.
  2. Browse to the Domain Orchestrator URL (the load balancer for the Domain Orchestrator, if clustered).
  3. Log in, click the Configuration tab, and then click the Installation palette.
  4. Under Install Cluster Node for Orchestrator, click Install to begin the upgrade.
  5. The language selection dialog appears first. Click OK.
  6. Click Next to the Welcome to the CA Process Automation 3rd Party Installer Setup Wizard page.
  7. For License Agreement, select I accept the terms of the license Agreement and then click Next.
  8. On the Select Destination Directory page, navigate to the directory you used for the previous release. For example, in Windows, the following are defaults, depending on the source release.
    C:\program files\ca\itpam
    C:\program files\ca\pam
  9. Click through the following Wizard pages:
  10. If you upgraded your JDK, browse to the Java Home Directory, for example, C:\Program Files\Java\jdk1.7.0_45
  11. Complete the Configuration Screen:
    1. If you have already upgraded a node in this cluster, select from the Orchestrator drop-down list the Orchestrator node that you upgraded first.
    2. Type node1, node2, node3, or node4 in the Load Balancer Worker Node field to identify the node you are upgrading.
  12. Type your company name, if not displayed
  13. Enter the certificate password.
    Important! This entry must match the certificate password that was entered when the Domain Orchestrator was upgraded.
  14. Click through the following pages, if they appear. Settings used by node1 are used by other nodes in the cluster.
    The upgrade installation begins.
  15. When Completing the CA Process Automation Setup Wizard page appears, click Finish.
    Processing continues after you click Finish.
  16. When processing completes, start the Orchestrator service on the upgraded cluster node.
    Note: See Start Orchestrators for operating system-specific details.
More information:
Example: Upgrade Any Node of the Domain Orchestrator from 3.1 SP01 to Release 4.2 on Windows
How to Upgrade CA Process Automation
Example: Upgrade Another Node of the Domain Orchestrator from 3.1 SP01 to Release 4.2 on Windows
