Previous Topic: Upgrade the Domain OrchestratorNext Topic: Upgrade a Cluster Node
Upgrade a Nonclustered Orchestrator
After you upgrade the Domain Orchestrator by invoking a script distributed on the media, you can upgrade other Orchestrators from the CA Process Automation UI.
  1. Log in to the host on with the Orchestrator to upgrade.
  2. Browse to CA Process Automation and log in with administrator credentials.
  3. Click the Configuration tab and select the Installation palette.
  4. Click Install in the Install Orchestrator section to begin the upgrade.
  5. Select a language and click OK.
    The Welcome to the CA Process Automation Third-Party Installer Setup wizard page appears.
  6. On the Licensing agreement page, select the option to accept the agreement, and then click Next.
  7. On the Select Destination Directory page, navigate to the directory that you used for the previous release. For example, in Windows, the following are defaults, depending on the source release.
    C:\program files\ca\itpam
    C:\program files\ca\pam
  8. Click Next to Prerequisites for CA Process Automation Installation.
  9. Specify JDBC jars for installation in one of the following ways:
  10. Click Next to confirm, and then click Finish to advance to the CA Process Automation installer.
  11. Click Next on the Welcome page
  12. Select the option to accept the license agreement and click Next.
  13. When the Java Home Directory page appears, browse to the location of the upgraded JDK and then click Next.
  14. Click Next to proceed through the following installation wizard pages:
  15. Enter the certificate password, and click Next.
    Important! This entry must match the certificate password that was entered when the Domain Orchestrator was upgraded.
  16. Click Next to accept the previous configuration on following installation wizard pages:
  17. Click Finish.
  18. When processing completes, start the Orchestrator service on the upgraded nonclustered Orchestrator.
    Note: See Start Orchestrators for operating system-specific details.
More Information:
Example: Upgrade a Non-clustered Orchestrator from 4.1 SP01 to Release 4.2 on Windows
How to Upgrade CA Process Automation
