The URL you use to access CA Process Automation depends on whether the Domain Orchestrator is configured with one node (nonclustered) or multiple nodes (clustered). You can browse directly to a nonclustered CA Process Automation. For a clustered CA Process Automation, browse to the associated load balancer. You can reach all Orchestrators in the domain by launching the URL to the Domain Orchestrator or to the load balancer for the Domain Orchestrator.
https://server:port/itpam
Examples:
https://Orchestrator_host:8443/itpam https://loadBalancer_host:443/itpam
http://server:port/itpam
Examples:
http://Orchestrator_host:8080/itpam http://loadBalancer_host:80/itpam
The CA Process Automation login page opens.
Note: If CA EEM is configured to reference users from multiple Microsoft Active Directories and CA Process Automation does not accept your unqualified user name, enter your principal name. One format for a principal name is domain_name\user_name.
CA Process Automation opens. The Home tab displays.
Copyright © 2014 CA.
