Previous Topic: Catalyst OperatorsNext Topic: Execute Parameters
Catalyst Security Parameters
All Catalyst operators include Catalyst Security parameters that support authentication at the Catalyst level and at the connector level.
After you get access to the Catalyst nodes, you can use claims to get connector-specific security information. See the Connector guide that is provided with the applicable Catalyst connector for information about connector-specific claims.
Administrators at the Domain level set the default security settings for the Catalyst operator category (which contains all of the Catalyst operators). These configurations are inherited. You can edit these settings for individual operators at the environment, Orchestrator, and agent levels.
See the UI Reference for information about security parameters at the operator category (or module) level. See the Content Designer Reference for information about security parameters for each operator.
