Previous Topic: Catalyst Process Automation ServicesNext Topic: Communications
Usage
Any Catalyst client interface, including the Catalyst REST interface and the Catalyst operators that CA Process Automation includes, lets you access Catalyst Process Automation Services.
All Catalyst operators interact with Catalyst connectors, which interact with a management data repository (MDR). A Catalyst connector always resides in a Catalyst container. The Catalyst container has a broker (a node lookup service) that publishes the node configurations for each connector in the container.
Catalyst Process Automation Connector Layout
All of the Catalyst operators require the Catalyst broker URL and the connector MdrProdInstance. When you enter a Catalyst broker URL in a Catalyst operator, the operator queries the broker for node configurations. The broker then populates the MdrProdInstance with a list of those node configurations.
After the Catalyst broker URL and the MdrProdInstance are defined in a Catalyst operator, you can specify the REST operations to run.
