Example
RESTful services let you import content from a server location.
Username: (Catalyst user name)
Password: (Catalyst password)
ClaimName: Username
ClaimValue: pamadmin
ClaimName: Password
CatalystBrokerURL: "https//hostname:7443/ucf/BrokerService"
MdrProduct: "CA:00074 (CA Process Automation)"
MdrProdInstance: "CA:00074:01"
Operation Category: "CA Process Automation"
Operation: Import
ImportLocation: Defines the Library location to which to import the XML file. If the specified folder does not exist, CA Process Automation creates it. For example, "/test-import/".
SourceLocation: Define the source folder in one of the following ways:
OverwriteAction: Enter one of the following options to import a file of the same name that exists in the specified location:
SetCurrent: Select "true" to set the imported version as current version; otherwise, select "false".
MakeAvailable: Select "true" to make the content available in the Library. Select "false" to make the content unavailable.
The following illustration shows a successful import message:
Copyright © 2014 CA.
