Previous Topic: VBScript Example: WinGetInfo Script InformationNext Topic: PerlScript Example: WinGetInfoPerl Script Operator
Script (VBScript)
The script creates two indexed fields, HostList and OSList in the WinGetInfo operator dataset. The script:
The script populates the oArgs.Item variable with the Parameters input area entries of the calling Run Script operator. The first entry populates oArgs.Item(0). The script assigns the number of rows it reads to the NumRowsRead operator dataset variable. The Wscript.sleep 30000 line pauses the operator for 30 seconds so the user can examine the folders and files created in the C2OSVD location. You would not include the Wscript.sleep 30000 line in a production script.
Dim oArgs
Dim oShell
Dim colProcessEnv
Dim objFSO
Dim objDir
Dim objFileIn
Dim objFileOut
Dim intCounter
Dim intExitCode
Dim strLine
Dim intSpacePos
Dim strHost
Dim strOS
on error resume next
set oArgs = WScript.Arguments
set oShell = WScript.CreateObject("WScript.Shell")
Set colProcessEnv = oShell.Environment("Process")
if oArgs.Count = 1 then		'must have the required argument
				to proceed normally,
				fails if more arguments are present
strSourceFile = oArgs.Item(0)
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objDir = objFSO.CreateFolder(colProcessEnv("C2OSVD"))
Set objDir = objFSO.CreateFolder(colProcessEnv("C2OSVD") & "\HostList")
Set objDir = objFSO.CreateFolder(colProcessEnv("C2OSVD") & "\OSList")
intCounter = 0
Set objFileIn = objFSO.OpenTextFile(strSourceFile, 1)
Do Until objFileIn.AtEndOfStream
strLine = objFileIn.ReadLine
intSpacePos = InStr(strLine, " ")
strHost = Left(strLine, intSpacePos - 1)
strOS = Right(strLine, Len(strLine) - intSpacePos)
Set objFileOut = objFSO.CreateTextFile(colProcessEnv("C2OSVD") & "\HostList\" & intCounter)
objFileOut.Write strHost
objFileOut.Close
Set objFileOut = objFSO.CreateTextFile(colProcessEnv("C2OSVD") & "\OSList\" & intCounter)
objFileOut.Write strOS
objFileOut.Close
intCounter = intCounter + 1
Loop
objFileIn.close
Set objFileOut = objFSO.CreateTextFile(colProcessEnv("C2OSVD") & "\NumRowsRead")
objFileOut.Write intCounter
objFileOut.Close
intExitCode = 0
else
'Wscript.echo "bad argument or required argument NOT present"
intExitCode = 5
end if
Wscript.sleep 30000
on error goto 0
Wscript.Quit intExitCode
