Previous Topic: Set Custom Operator Availability to All UsersNext Topic: Using Custom Operators
Publish a Custom Operator Group Configuration to Another Domain
When you define a custom operator group, the group automatically publishes to the current Domain and to all environments in the Domain.
When you import to a different Domain, the process lets you publish the custom operator group to that Domain and to all of its environments. The Publish Custom Operator Group Configuration option requires Group_Config_Admin rights. Administrators (members of the PAMAdmins group) have this right.
  1. In the Library browser for the selected Orchestrator, select the destination for the imported items.
  2. Right-click the parent folder, then click Import.
  3. Click Browse, browse for the XML file in the Open window, then click Open.
  4. Select one of the following options that specify how to handle objects with conflicting names. If you import into an empty folder, there can be no conflicts.
  5. (Optional) Select the Set Imported Version as Current check box.
    This option applies if you selected Import as a New Version and Keep the Existing Object in Step 4.
  6. Select the Make Imported Custom Operators Available check box.
    You cannot use custom operators until they are made available.
  7. Select the Publish Custom Operator Group Configuration check box.
    Publication publishes the custom operator groups to the import Domain and to all environments in this Domain.
  8. Click Submit.
  9. Click OK on the successful import confirmation message.
    The import recreates the exported folder structure in the selected location, imports the custom operators, and publishes the custom operator group and related variables.
More information:
Custom Operator: Group Configuration Tab
Example: Retrieve Valuemap Array Values with an Operator System Function
Release Objects to Another Environment
