Previous Topic: Apply a Custom Icon to Any Operator in a ProcessNext Topic: Custom Icon Examples
Apply a Custom Icon to a Custom Operator
You can change the icon for a custom operator. The icon that you select applies to all future occurrences of the custom operator in processes. Existing occurrences of the custom operator in processes continue to show the original default icon for the base operator.
  1. Click the Library tab
    A hierarchical list of folders appears in the left pane and all your automation objects are listed in the main window by type.
  2. Double-click a custom operator.
    The Custom Operator window appears.
  3. In the toolbar, click Check Out.
  4. Click the Settings tab.
  5. On the Settings tab, click the Change Icon link.
  6. In the Select Custom Icon dialog, browse to the custom icon, select it, and click OK.
  7. Click Save.
  8. (Optional) If none of the existing icons are appropriate, edit a custom icon or create a new one.
Note: You cannot change the icons that are associated with the execution state of a custom operator. For example, waiting or completed. CA Process Automation automatically manages these icons.
