Configuration Tab › Mapping for Configuration Browser Tabs › Triggers
Triggers
One or more of the following fields appear on the Triggers tab for the selected node.
- Name and Description appear for Domain.
- Name and Enable/Disable appear for environment, Orchestrator touchpoints, and Orchestrators. The Enable/Disable setting can be made active by locking the selected environment or Orchestrator host node.
Note: For information about configuring triggers, see "How to Configure and Use Triggers" in the Content Administrator Guide.
- Name
Lists the names of the four CA Process Automation triggers, with right-click options to Edit or View the selected trigger.
- Description
Displays a short description of the corresponding trigger.
- Enable/Disable
Specifies the status of each trigger at the selected node. This field is read-only for Orchestrator touchpoints.
Values: This value can be one of the following:
- Enabled - At the environment level, enables the right-click Edit option that allows you to override inherited values for this trigger.
- Disabled - Indicates that this trigger is not ready for use.
- Inherit from Domain (environment nodes) - Inherits values set at the Domain level.
- Inherit from Environment (Orchestrator hosts) - Inherits values set at the parent environment.
Default: Disabled
Copyright © 2014 CA.
