The SNMP trigger configuration specifies the process to run upon the receipt of an SNMP trap meeting the specified filter criteria. The following descriptions are for fields to configure on the General Properties tab of the SNMP Trigger dialog.
Specifies SNMP trigger properties that enable processes to be triggered upon the receipt of an SNMP trap.
Describes the SNMP trap filter.
Specifies the IPv4 subnet in CIDR format against which the source IP address is matched. For example: 172.24.36.0/24 matches any source IP address in the range from 172.24.36.1 to 172.24.36.254, not counting the network address and the broadcast address, which are not assigned to hosts. To accept traps from all source IP addresses, enter 0.0.0.0/0.
Specifies a regular expression matching the SNMP trap object identifier (OID). An OID is a unique numeric identifier for a data object that is paired with a value in an SNMP trap message.
Values:
Specifies a regular expression matching any of the payload values of the trap. Leave blank (or type .*) to accept SNMP traps with any payload content. For example, testpayload.
Specifies the full path of the Process to run when receiving an SNMP trap that matches the filter criteria. The checked-in version of the Process Path is used during execution.
Note: Click search to load the Object Browser, from which you can select the process path.
Copyright © 2014 CA.
