Previous Topic: Simplified Communication Fails After Changing the Orchestrator URLNext Topic: Third_Party_Installer_unix.sh: Permission Denied
Oracle Locks Can Occur If You Do Not Shut Down Running Processes Before Starting an Upgrade
For a smooth upgrade to Release 4.2, verify that there are no running instances before starting the upgrade.
Symptom:
If you start an upgrade where processes are running and the Runtime database is on an Oracle database server, you can experience issues with a lock not being released. After the upgrade, when the server tries to adjust the database, an exception similar to the following can occur:
ORA-01591 lock held by in-doubt distributed transaction
This causes the environment to fail functionally after the upgrade.
Note: This situation rarely occurs.
Solution:
Resolve transactions noted by "ORA-01591 lock held by in-doubt distributed transaction" in the following cases:
To correct this problem, manually execute the ROLLBACK on the Oracle database.
  1. Identify the transaction identification number for the in-doubt transaction by querying DBA_2PC_PENDING views. Execute following query for the same:
    select * from DBA_2PC_PENDING
  2. Check the state of the transaction. If state is PREPARED then either:
