This section describes the troubleshooting methods to use CA Process Automation.
This section contains the following topics:
Unable to Install Agent with Oracle JD7 Update 51
CPU Usage Spikes in server nodes with Secured Simplified Communication and Load Balancer
CPU Usage Spikes in server nodes with Secured Simplified Communication and F5 Load Balancer
Simplified Communication Fails After Changing the Orchestrator URL
Oracle Locks Can Occur If You Do Not Shut Down Running Processes Before Starting an Upgrade
Third_Party_Installer_unix.sh: Permission Denied
Stop Processes Before an Upgrade
CA Process Automation Installation Fails
Limitations in Internet Explorer
CA Process Automation Installation on Dual Stack (IPv4 and IPv6) Network Environments
Unable to Create Runtime Database
Unable to Execute Run Script or Run Program Operators on RHEL6
Copyright © 2014 CA.
