Previous Topic: CPU Usage Spikes in server nodes with Secured Simplified Communication and F5 Load BalancerNext Topic: Oracle Locks Can Occur If You Do Not Shut Down Running Processes Before Starting an Upgrade
Simplified Communication Fails After Changing the Orchestrator URL
You can change the URL of the Domain Orchestrator during a reinstall or you can make a port change to the existing URL through an OasisConfig.properties file change.
Symptom:
Agents that use simplified communication stop communicating with an Orchestrator after that Orchestrator URL is changed, including a change in port number.
Note: Simplified communication is configured by clearing the “Use deprecated communication” check box in the agent properties.
Solution:
Reinstall all agents that are associated with touchpoints in the environment with the affected Orchestrator.
