Previous Topic: Search for Release Version InformationNext Topic: Search for Audit Trail Information
Search for Version Information
The Version tab lets you filter the displayed versions to objects that contain the string you specify.
  1. Click the Library tab.
  2. Right-click an object and select Edit.
    The object editor appears.
  3. Click the Versions tab.
  4. Click the magnifying glass icon on the right-hand side of the Version toolbar.
    The search field and Search button appear.
  5. Enter search criteria in the search field and click Search.
    The search process displays objects meeting the specified search criteria. Search criteria other than dates returns all versions containing the specified string in the Version, Modified By, and Created By fields. Date search criteria returns all versions with an exact match in the Created On and Last Modified On fields.
