Previous Topic: Search for Version InformationNext Topic: Working with Objects and Folders
Search for Audit Trail Information
The Audit Trail tab lets you display only object versions that meet one or both of the following search criteria:
  1. Click the Library tab.
  2. Right-click an object and select Edit.
    The object editor appears.
  3. Click the Audit Trail tab.
  4. Click the magnifying glass icon on the right-hand side of the Audit Trail toolbar.
    The search fields and Search button appear.
  5. Enter search criteria in either the Filter field, the From and To fields, or both. Then, click Search.
    Filter
    Specifies the numeric or alphanumeric search criteria for the following fields, where the search results include any object versions that contain the specified string.
    • Version
    • Username
    From - To
    Specifies date range criteria for searching the Last Updated data.
    The search process displays objects meeting the specified search criteria.
