Previous Topic: Search the Library BrowserNext Topic: Search for Version Information
Search for Release Version Information
You can optionally associate each object version with a release version. The Versions tab uses its displayed associations to filter for those objects and versions that are associated with a string you specify. You can search a specific release version to display a version of interest. Alternatively, you can search for a generic string that returns multiple object versions. The Versions tab supports wildcard searches with or without a wildcard character (*), as the following example shows:
Search String
Search Results
5
Any object version in which the Version field or the Release Version field contains the character 5.
*5
5*
*5*
  1. Click the Library tab.
  2. Right-click an object, and then select Edit.
  3. On the object editor, click the Versions tab.
    Note: See the tooltips or the User Interface Reference for field descriptions and examples.
  4. On the Version toolbar, click the magnifying glass icon on the rightmost side. Search icon indicated by a magnifying glass.
  5. Enter search criteria in the search field, and then click Search.
    The search returns the objects and versions that are associated with the specified string.
