Administer Agents › How to automatically Upgrade Agents through CA Process Automation Content › Run the Post-Upgrade Content › View the Output after Content Execution
After the post-upgrade content is run successfully, the following datasets are updated:
- Agent Details dataset in Pre-Upgrade Content folder
Contains information regarding agents that are successfully upgraded.
Note: The IsReinstalled field in the Agent Details dataset is set to ‘true’ for the agents that are successfully upgraded.
- Failed Agent List dataset in Output folder under Post-Upgrade Content
Contains the agents that failed to upgrade.
Note: If there are no failed agents, then the Failed Agent List dataset is not displayed.
- Double-click the Agent Details dataset from the PostUpgrade Process Watch and verify the details for the agents that are successfully upgraded.
- Double-click the Failed Agent List dataset and verify the details for the agents that failed to upgrade.
Copyright © 2014 CA.
