The post-upgrade content enables you to upgrade the active agents in the AgentDetails dataset to the CA Process Automation 4.2 SP2 release. The steps involved in upgrading the active agents to the CA Process Automation 4.2 SP 2 release are as follows:
When you run the post-upgrade content, the active agents in the AgentDetails dataset are upgraded to the 4.2 SP 2 release.
Enter the certificate password for the domain orchestrator.
Note: The entered password displays in plain text.
Enter the username and password for each orchestrator node in the cluster setup.
Important: The Operating system account credentials (username and password) are assumed to be same across the nodes.
The content runs for both Windows and non-windows agents. The 'Select Agents to Upgrade' task displays with the Pending status in the Group Tasks tab of the Tasks pane.
The status of the 'Select Agents to Upgrade' task changes to Completed. The 'Results for Upgrade Agents' task can take more time to populate in the Tasks > Group Tasks pane, based on the number of agents that are selected.
The resultant task displays a success message for successful upgrade. However, agents can fail to upgrade for many reasons and you can decide to resolve the problems associated with the agents and rerun the SRF Upgrade Agents as follows:
Until all agents are upgraded, you can rerun the content for the agents that fail to upgrade. The details of the agents that fail to upgrade are saved in the Failed Agent List dataset.
Copyright © 2014 CA.
