The pre-upgrade content enables you to obtain the details of the agents in the existing environment. The steps that are involved in obtaining the details for agents are as follows:
To obtain the details of the agents in the existing environment, run the pre-upgrade content. The pre-upgrade content uses the details of the agents to upgrade the agents to the current release.
Important! Run the content before you upgrade the domain orchestrator to a new version.
The content starts obtaining details of the agents in your environment and is run for both windows and non-windows agents.
Based on the number of agents in your environment, the ‘Results for Get Agents Details’ task can take more time to populate.
If there are no inactive agents, a success message displays in the task. However, agents can fail due to many reasons and a list of inactive agents is displayed for the same.
You can decide to resolve the problems with the inactive agents and rerun the SRF Get Agents Details as follows:
Note: For more information, see Start the Agent in the CA Process Automation Installation Guide.
The content updates the details of the agents in the Agent Details and Inactive AgentList datasets. Information regarding the inactive agents that are activated is appended to the Agent Details dataset and the Totalnumberofactiveagents field is increased.
Similarly, the information regarding the inactive agents that are activated is removed from the InactiveAgentList dataset. You can run the content until the Totalnumberofinactiveagents field changes to zero.
The content is run successfully and the status of the 'Results for Get Agents Details' task changes to Completed. Also, the state of the Get Agents Details instance changes to Completed.
Notes:
During operator execution in CA Process Automation, when the operator is unable to find the c2oHome location of the agent or the orchestrator, the Echo Off error displays in the Operator Runtime dataset.
To mitigate the issue, follow these steps:
Copyright © 2014 CA.
