Administer Agents › How to automatically Upgrade Agents through CA Process Automation Content › Review Terminologies, Limitations, Assumptions and Prerequisites
Review the following terminologies before you run the content:
- Active agents
Indicates the agents for which the pre-upgrade content obtains the details.
- Inactive agents
Indicates the agents for which the pre-upgrade content does not obtain the details.
- Content
CA Process Automation content that is designed using automation objects for automatically upgrading agents.
Note: The following steps are optional:
- View the Output after content execution:
After the content is run, the results are saved in the datasets. Whenever required, you can verify the output using the datasets.
- Verify the upgraded agents after the post-upgrade content is executed:
The IsReinstalled field in the Agent Details dataset is set to ‘True’ for the agents that are successfully upgraded.
Review the following prerequisite before you run the content:
- Create touchpoints for the agents you want to upgrade before you run the pre-upgrade content. For more information about creating touchpoints, see Administer Touchpoints in the CA Process Automation Content Administration Guide.
Review the following limitations before you run the content:
- The content is not supported when domain orchestrator runs on non-windows platform, that is, Linux, Solaris.
- You cannot use the content to upgrade from the CA Process Automation 4.2 version to 4.2 SP2 version.
- Agents that run in console mode can fail to upgrade.
- The Certificate Password field in the Upgrade Agents form is plain text instead of a password field.
- No support for agents that run on Windows 2003 Server R2 and Windows XP.
Review the following assumptions before you run the content:
- Orchestrator and agents run in service mode.
- Domain orchestrator is installed on the Windows platform.
- By default, FTP/SFTP and SSH are enabled for non-windows agents.
Import the Content
The installation media contains content (CA PAM Upgrade Agents.xml) that enables you to upgrade the agents automatically.
- Import the content to any folder as follows:
- For the CA Process Automation 3.1 version:
- Log in to PAM and click CA Process Automation Client.
The previously installed agents are listed in the Configuration browser.
- Access the Library folder, right-click the folder, select the content, and click Import.
- For CA Process Automation 4.0 and 4.1 versions:
- Log in to CA Process Automation.
- Access the Library tab, right-click the folder, select Import, select the Content, and click Open.
After the content is imported successfully, a folder with the name, CA PAM Upgrade Agents is created in the left pane.
- Verify the following folders in the CA PAM Upgrade Agents folder:
- Pre-Upgrade content
- Post-Upgrade content
Important! Do not modify to the objects in the Core Content and Output folder.
Copyright © 2014 CA.
