As mentioned previously, an example response file has been provided in the root folder of DVD1. The parameters that are required to perform an unattended installation of CA Process Automation include the following list. Parameters that are not included in this list are optional.
thirdPartyLicenseAccepted
licenseAccepted
sys.installationDir
javaHome
domainInstallerDir
isSecure (true/false)
The port used for simplified communications for the Domain Orchestrator.
The entry for the CA EEM SDK level.
Specifies whether to provide a connection URL. This is only applicable with Oracle.
JDBC Connection URL.
Example:
jdbc:oracle:thin:@(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=<database host name>) (PORT=<portnumber>)) (CONNECT_DATA=(SERVICE_NAME=<libDb>))).
Note: The last two entries appear three times; twice for each database. These parameters are only applicable if you select Oracle as your database and you use a connection string.
