The first step in performing a silent installation of CA Process Automation is to create a response file.
Consider the following notes about the response file:
${install_dir}/server/c2o/installation.log
response.varfile
The varfile includes parameter descriptions. For example, to enable CA EEM to use the NTLM protocol to authenticate CA Process Automation users, use the following setting:
enableNTLM=true
Required parameters can be found here.
The response file is created.
