An operator runs on an Orchestrator by default, but you can specify a specific location (target) in the execution settings.
Targets can be specified as a touchpoint, touchpoint group, agent ID, proxy touchpoint, or an IP address or FQDN. See How Targets for an Operator Can Be Specified in the Content Designer Guide for a description of each of these items. Each target ultimately resolves to an Orchestrator, one or more agents, or a remote host with an SSH connection to an agent. Where the operator runs is significant because in some cases the process that is being designed must operate on a specific host. Many operators can execute on either an Orchestrator or on agents. However, certain operators can execute only on Orchestrators; another can execute only on agents. Others require that the targeted remote host support SSH access.
We recommend that you dedicate an agent to running Invoke Java operators. This is the only CA Process Automation operator than cannot run on an Orchestrator.
Note: Agents acting as proxy touchpoints have different category requirements. Operations that target proxy touchpoints (or a remote host referenced by a host group) go through SSH.
Category |
Operator |
Orchestrator |
Agent |
Remote Host (SSH Target) |
All |
x |
Run Program |
x |
x |
x |
Run SSH Command |
x |
x |
Run SSH Script |
x |
x |
Run Script |
x |
x |
x |
Run Telnet Command |
x |
x |
Run Telnet Script |
x |
x |
Bulk Insert into Database |
x |
x |
x |
Delete from Database |
x |
x |
x |
Get Database Schema |
x |
x |
x |
Get Free Space |
x |
x |
x |
Get Stored Procedure |
x |
x |
x |
Get Table |
x |
x |
x |
Get Used Space |
x |
x |
x |
Get Version |
x |
x |
x |
Get View |
x |
x |
x |
x |
x |
x |
Query Database |
x |
x |
x |
Select from Database |
x |
x |
x |
Update in Database |
x |
x |
x |
Check Calendar |
x |
Check Date-Time |
x |
Add Computer to Domain |
x |
x |
Add User to Group |
x |
x |
Create Group |
x |
x |
Create Object |
x |
x |
Create Organizational Unit |
x |
x |
Create User |
x |
x |
Delete Object |
x |
x |
Get Domain Controller |
x |
x |
Get Dormant Account |
x |
x |
Get Object |
x |
x |
Get User |
x |
x |
Move Object |
x |
x |
Remove User from Group |
x |
x |
Update Object Attributes |
x |
x |
Update User Home Directory |
x |
x |
Create Folder |
x |
x |
Delete Email |
x |
x |
Delete Folder |
x |
x |
Get Email Content |
x |
x |
Get Email Count |
x |
x |
Get Email Envelope |
x |
x |
Get Email List |
x |
x |
Move Email |
x |
x |
Purge Folder |
x |
x |
Rename Folder |
x |
x |
Send Email |
x |
x |
Compress File |
x |
x |
x |
Copy File |
x |
x |
x |
Create Folder |
x |
x |
x |
Decompress File |
x |
x |
x |
Delete File |
x |
x |
x |
Get Directory Content |
x |
x |
x |
Get File Attributes |
x |
x |
x |
Monitor File |
x |
x |
x |
Read from File |
x |
x |
x |
Rename File |
x |
x |
x |
Search File Content |
x |
x |
x |
Update File Ownership |
x |
x |
x |
Update File Permission |
x |
x |
x |
Update File Timestamp |
x |
x |
x |
Write File |
x |
x |
x |
Create Directory |
x |
x |
x |
Delete Directory |
x |
x |
x |
Delete File |
x |
x |
x |
Download File |
x |
x |
x |
Get File Information |
x |
x |
x |
Move File |
x |
x |
x |
TFTP Download File |
x |
x |
TFTP Upload File |
x |
x |
Upload File |
x |
x |
x |
Get MBean Attributes |
x |
x |
Invoke MBean Method |
x |
x |
Update MBean Attributes |
x |
x |
Get Local Network Interfaces |
x |
x |
Get Network Services Status |
x |
x |
Get SNMP Variable |
x |
x |
Monitor SNMP Variable |
x |
x |
Ping Host |
x |
x |
Send SNMP Trap |
x |
x |
Update SNMP Variable |
x |
x |
Assign User Task |
x |
Evaluate Expression |
x |
Manage Resources |
x |
Monitor Event |
x |
Send Event |
x |
Start Process |
x |
Start |
x |
Comment |
x |
Stop Success |
x |
Stop Failure |
x |
Process Progress |
x |
And |
x |
Or |
x |
Reset |
x |
Loop |
x |
Change Lane |
x |
Exception |
x |
Apply Xpath |
x |
Apply XSLT |
x |
Delay |
x |
Invoke Java |
x |
Run JavaScript |
x |
HTTP Delete |
x |
x |
HTTP Get |
x |
x |
HTTP Head |
x |
x |
HTTP Options |
x |
x |
HTTP Post |
x |
x |
HTTP Post Form |
x |
x |
HTTP Put |
x |
x |
HTTP Trace |
x |
x |
Invoke SOAP Method |
x |
x |
Invoke SOAP Method Async |
x |
x |
