Operator configuration options display in the Properties window when you double-click an operator in a process or schedule object.
Configuration for operator categories is described in the Content Administrator Guide.
Note: Verify that the Properties check box is selected if the properties for an operator do not display. Select View, Properties in the top right-hand corner of the Designer, then maximize the Properties window at the bottom of the screen. If the operators themselves do not display, click Operators under the View menu.
