The File Management operators monitor directories, files, and their contents. These operators can be run either locally or on a remote system. The File Management operators also support operations on a proxy node. The process takes either a success or a failure path, based on the results of the operation.
Use the File Management operators to create, delete, rename, compress and uncompress local files. You can also use the File Management operators to watch files on the touchpoint where the operators are running. All File Management operators run under the same user name that is running the touchpoint, such as administrator on a Windows touchpoint or root on a UNIX touchpoint.
The File Management operators can run on proxy agents. Properties in a normal and proxy service are the same, but some behavior is different. For example, if the Process Proxy Service is running with the log output option checked, then the log file is created on the file system where the agent is running. The log file is not created on the machine where the proxy agent resides.
Important! The following conditions apply to all operators in this category when running them on a remote Windows host through a proxy touchpoint::
- Use UNIX-style paths for fields which are path-related (forward slashes and no drive letter).
- Each SSH server can have a different location for its "root" directory. The permitted commands that are relative to that root directory can vary too.
