HTTP URL Information
See HTTP URL Information for descriptions of input parameters.
HTTP Post Form Information
Specifies the character encoding to use when encoding the form fields parameters. The data in the HTTP Post Form operator goes in the body of the request.
This field accepts the following values:
ISO-8859-1
Specifies whether to specify form fields in the Form Fields Indexed Value Map field or in the Form Fields field. The choice enables entry to the corresponding field.
Specifies the combination of key and value for each form field. The Key column contains the names of the form fields and the Value column contains the values of the form fields.
Use the buttons to add, remove, or reorder parameters.
Note: The HTTP Post Form operator ignores any form field with a blank Key.
Specifies the name of an indexed ValueMap.
This Value Map consists of Key and Value. A Key entry is the name of a form field; the corresponding Value entry is the value of that form field. The indexed ValueMap is in the same format as the one listed in the Form Fields field.
Indicates whether the form contains fields that allow for files to be uploaded to the form. Selecting this check box lets you enter related data in the following fields: Use Indexed Value Map for Form Files?, Form Files, and Form Files Indexed Value Map.
Note: The HTTP request header content-type depends on how the File Fields in Form? field is set.
This field is set in one of the following ways:
content-type=multipart/form-data;boundary=XXXXXXX
content-type=application/x-www-form-urlencoded;charset='encoding'
Indicates whether to specify the form file fields in the Form Files field or in the Form Files Indexed Value Map field.
Specifies each form file with four fields: Key, File Path, Content Type, and Content Character Encoding. Descriptions of each field of a form file follow:
Specifies the names of the form file fields.
Specifies the path to the file to upload. (This field is required.) The operator ignores any form file field with a blank FilePath.
Specifies the content type of the file to upload. Valid content-types are listed on the IANA website under assignments/media-types. If left blank, the content-type of the corresponding file’s part in the HTTP request body is set to application/octet-stream. It is then the responsibility of the HTTP server to interpret this generic content-type.
Specifies the character set of the content of the files to upload, if the corresponding content type is all characters such as ‘text/XXX’. Leave blank for other kinds of content types.
Note: For a list of different character sets (encodings), see the IANA website pages under assignments/character-sets.
Specifies the name of an indexed ValueMap that contains the form file fields names and corresponding values. The indexed ValueMap must be of the same format as the one listed in the Form Files field. That is, it must consist of Key, FilePath, ContentType, and ContentCharacterEncoding.
HTTP Proxy Information
See HTTP Proxy Information for descriptions of input parameters.
HTTP Headers Information
See HTTP Headers Information for descriptions of input parameters.
HTTP Cookies Information
See HTTP Cookies Information for descriptions of input parameters.
HTTP Response Content Information
See HTTP Response Content Information for descriptions of input parameters.
HTTP Configuration Information
See HTTP Configuration Information for descriptions of input parameters.
